configure erps control-mac
configure erps ring-name control-mac [auto | default]
Description
Configures ERPS control MAC (either default or auto) on a particular ERPS ring instance.
Syntax Description
erps Specifies ERPS (ITU-T G.8032).
ring-name Specifies the alphanumeric string that identifies the ERPS ring/sub-ring.
control-mac Destination MAC used in R-APS PDUs .
auto Use ring ID-based MAC address (01:19:A7:00:00:ring-id).
default Use default MAC address (01:19:A7:00:00:01).
Default
By default, if an ERPS ring instance is created with a user-defined ring ID, the control MAC used by ring instance is auto (01:19:A7:00:00:ring-id).
By default, if an ERPS ring instance is created without a user-defined ring ID, the control MAC used by the ring instance is default (01:19:A7:00:00:01).
Usage Guidelines
As per the ITU G.8032 standard, destination MAC used in R-APS PDUs are of 2 types:
  • 01:19:A7:00:00:01 (default)
  • 01:19:A7:00:00:ringId (auto)
This command is only applicable on ERPS ring instances created with user-defined ring ID.
The following example configures the control MAC of an ERPS ring instance created with a user-defined ring ID:
# configure  erps Ring2 control-mac auto
The following example configures the control MAC of an ERPS ring instance created without a user-defined ring ID:
# configure  erps Ring1 control-mac auto
       Error: This cli is applicable only when the erps ring is created with a user defined ringId. The default
       control-mac is used here.
This command was first available in ExtremeXOS 33.1.1.
Platform Availability
